Enabling Bluetooth on the Alpha® Handheld
- Select Setup.
- Select Bluetooth.
- Select Continue.
Pairing to the Alpha Mobile App
Open and sign in to the Alpha Mobile app on the smartphone:
Select Pair Device on the first screen prompt.
- NOTE: If you are not prompted to pair, touch
Devices at the bottom of the screen, then touch Pair Device or +.
- Select your model of Alpha handheld
- The app will present a list of potential nearby Bluetooth devices that are transmitting or already in the Bluetooth list.
- Select your Alpha model
- After several moments the Alpha and the smartphone will both show a passkey number to verify the correct device being paired.
- A Bluetooth Pairing Request notification will pop over the app, touch Okay to confirm the pairing request.
- On the smartphone, touch Continue to finish the pairing process.
- On the Alpha handheld, touch Done.
The devices are now paired.
