Screen Timeout Setting on a Lily, Vivomove, or Vivosmart Series Watch
The Lily® and select vívosmart® and vívomove® watches have a timeout setting that allows you to set the length of time before the screen backlight turns off. A longer timeout will allow the backlight to stay on longer but will decrease battery life, while a shorter timeout will cause the backlight to stay on for a shorter amount of time but will increase battery life. Since these watches do not feature an always-on display option, changing your timeout settings can help you manage how long the screen stays visible.
For instructions on how to adjust this setting select your watch model below to reveal instructions.
Lily® Watches
To adjust the timeout setting using your Garmin Connect™ account, select your preferred platform below.
Garmin Connect App Instructions
  1. Open the Garmin Connect app.
  2. Access the menu by selecting More (bottom right).
  3. Select Garmin Devices.
  4. Select your Lily.
  5. Select Appearance or System.
  6. Select Display or Display Options.
  7. Select General Use, During Activity, or During Sleep (Lily®2 Active only).
  8. Select Timeout.
  9. Select your preferred timeout length.
  10. Back out of the settings to save your changes.
  11. Sync your watch to apply the changes.
Garmin Connect Web Instructions
NOTE: The steps below are not available for the Lily® 2 or Lily® 2 Active. Refer to the steps above using the Garmin Connect App.
  1. Sign into Garmin Connect web from a personal computer.
  2. Select Devices & Sync Status Silhouette of a watch (top right).
  3. Select your Lily.
  4. Select Appearance.
  5. Beneath Display Options, select your preferred Timeout length from the dropdown menu.
  6. Select Save Settings.
  7. Sync your watch to apply the changes.
Lily® Watch Instructions
vívomove® HR Watch
To adjust the timeout setting from the watch see: vivomove HR Display Settings.
To adjust the timeout setting using Garmin Connect, select your preferred platform below.
  4. Select your vivomove HR.
  5. Select Device Settings.
  6. Select Display Options.
  7. Select Auto-On Display.
  8. Select your preferred timeout length.
  9. Back out of the settings to save your changes.
  10. Sync your watch to apply the changes.
  1. Sign into Garmin Connect from a personal computer.
  3. Select your vívomove HR.
  4. Select Device Settings.
  5. Beneath Device Display, select your preferred Timeout length from the dropdown menu.
vívomove Watches
These steps are for the: vívomove 3 | vívomove 3S | vívomove Style | vívomove Luxe | vívomove Sport
  4. Select your vívomove watch.
  5. Select Appearance.
  7. Select your preferred timeout length.
  8. Back out of the settings to save your changes.
  9. Sync your watch to apply the changes.
  3. Select your vivomove watch.
vívomove® Trend Watch
  4. Select vivomove Trend.
  5. Select Display.
  6. Select Timeout.
  7. Select: Short, Medium, or Long.
  8. Sync your device.
vívosmart® 3 Watch
To adjust the timeout setting from the watch see: vivosmart 3 Display Settings.
  4. Select your vívosmart 3.
  5. Select Display Settings.
  6. Select Auto-on Display.
  3. Select your vivosmart 3.
vívosmart® 4 Watch
The timeout setting can only be adjusted using Garmin Connect. Select your preferred platform below.
  4. Select your vivosmart 4.
  3. Select your vivosmart 4.
  5. Select your preferred Timeout length from the dropdown menu.
vívosmart® 5 Watch
To adjust the timeout setting from the watch see: vivosmart 5 System Settings.
To adjust the timeout setting using Garmin Connect, see the steps below:
Garmin Connect App
  4. Select vívosmart 5.
  7. Select Timeout
  8. Sync your watch to apply the changes.
For Venu® watches see: Is There a Setting to Keep the Display on My Venu Series Watch Always On?
For vívosport, or vívoactive watches, refer to your owner's manual.
