Requesting Weather Forecasts With the Alpha 200i or 300i
The Alpha® 200i dog tracking handheld is able to request Basic, Extended, or Marine weather forecasts for viewing on the device or in the Garmin Messenger™ app or Garmin Explore™ app. With up-to-date software, the Alpha 300i dog tracking handheld automatically provides both premium/extended forecast data and marine forecast data, if available, whenever a new forecast is requested. This article will cover how to request weather forecasts from the dog tracking handheld only. For information on requesting weather using the Garmin Messenger app or Garmin Explore app, see Related.
Important Notes
  • Updating a forecast may incur data charges or additional usage charges.
  • For more information about Basic, Extended, and Marine weather, see - Frequently Asked Questions on Weather for inReach®.
  • A marine forecast will be included for locations on an ocean or other large body of water, if available. If you are unable to get a marine forecast, select a location further from shore.
Requesting a Weather Forecast
  1. From the home screen, select inReach.
  2. Select inReach Weather.
  3. Select New Forecast.
    OPTIONAL: On the Alpha 200i, select Forecast Type, Location, or Marine to change any of these settings.
  4. Select Get Forecast.
The handheld will then send a request for the forecast. It can take several minutes to receive the weather forecast data. Ensure you have a clear view of the sky. Once the handheld receives the forecast, you can view the forecast at any time until all the information in the forecast has expired. The forecast can also be updated at any time.
Example Weather Forecasts
Land Forecast
Land Weather Forecast
Marine Forecast
Marine Weather Forecast OverviewMarine Weather Forecast Detailed View
The following are examples of included data and icons when a weather forecast is requested.
  • Precipitation Percentage Precipitation Percentage
  • Temperature High and Low Temperature High and Low
  • Wind Speed and Wave Height Wind Speed and Wave Height (Marine Forecasts Only)
For examples of other weather related icons, see - Frequently Asked Questions on Weather for inReach.
Related
