Advanced Detour Options on Compatible Automotive Devices
The Detour button as a map button or map tool under View Map to avoid obstacles ahead of you, such as construction zones or closed roads.  You can access the Detour button by touching on the menu button (three lines in the bottom right) on the View Map screen.
When the Detour button is touched, it will give the following detour options:
  • 1/2 Mile
  • 2 Miles
  • 5 Miles
  • Detour By Road(s) in Route
The 1/2 Mile, 2 Miles, and 5 Miles option will navigate you off the route for the selected distance.
The Detour By Road(s) on Route option will provide a list of the roads along your route that you can select to specifically detour around.
The Advanced Detour option will need to be enabled on your device to get the above options.
To turn on Advanced Detour on your device:
  1. Touch Settings
  2. Touch Navigation
  3. Touch Advanced Detours
The device is now set up for Advanced Detours. Repeat these steps to turn this feature off.
