Pairing a Dog Tracking Collar to the Alpha 100
Up to 20 compatible dog tracking collars can be paired to the Alpha® 100 dog tracking handheld wirelessly using MURS/VHF, by entering the track and control codes, or by sharing wirelessly from another handheld using ANT+ technology.
Adding a Dog Collar Wirelessly using MURS/VHF
To pair wirelessly, the collar should be within close proximity (approx. 10 feet) to the handheld and away from sources of interference.
Ensure the removable antenna is installed on the Alpha 100 handheld.
Power on the Alpha 100 handheld.
Put the dog collar in pairing mode. For steps, choose your collar model below.
TT15, TT15 Mini, T5, or T5 Mini Collars
Start with the dog collar powered off.
To enter pairing mode, press and hold the power button on the collar until it emits two beeps.
Release the power button immediately after hearing the two beeps.
The status LED flashes rapidly in green when it is ready to pair.
TT15X or T5X Collars
X-series collars can enter pairing mode both when powered on or off.
Press and hold the power button on the collar until it emits a series of two beeps.
Release the power button immediately after hearing the two beeps. NOTE: If the button is held too long after the beeps, the collar will exit pairing mode.
Alpha T20 or Alpha TT25 Collars
Press and hold he power button on the collar until it emits two beeps.
Release the power button upon hearing the two beeps.
The LED light will flash blue indicating that it is in pairing mode.
Select Dog List.
Select Add Dog.
Select Pair Collar.
Use the keyboard to enter a dog name.
Select Finish. NOTE: If you have other collars to add, select Add More.
Using Track and Control Codes to Add a Dog Collar
Dog collars can be paired to an Alpha 100 handheld using track and control codes if the collar has already been paired to a different handheld. Track codes allow the Alpha 100 handheld to track the collar; Control codes allow the handheld to both track and use training functions of the collar.
Select Dog List.
Select Add Dog.
Select No.
Select Yes.
Enter the track or control code for the collar. NOTE: For steps to find the share code for the collar, reference "Locating Track and Control Codes" below.
Select
Select
Alpha® XL Navigator
Select Pro View
Select a dog
The Track and Control codes are displayed below the dog's name.
