How Are Calories Tracked on My Edge 20/25?
Depending on what accessories1 are used with the Edge, calories burned during a recorded activity will be calculated using the following data:
  • Speed, Distance, and User Profile - calculated using speed and distance from GPS or an ANT+ enabled speed sensor1 and user profile data.
  • Heart Rate - generic heart rate based calorie algorithm using heart rate data from an ANT+ enabled heart rate monitor1 and user profile data.
1The Edge 20 is not compatible with ANT+ enabled fitness sensors. Only the Edge 25 can be paired with ANT+ enabled fitness sensors.
