Venu 2 Plus Battery Life Expectations
The battery life of your Garmin watch may be affected by how you use the watch. The information in the tables below is intended to outline the conditions used to determine the battery life specifications. Usage beyond what is listed below, or usage of features not listed, may result in reduced battery life. The information presented below is presented as a general guide for reference only for the Venu 2 Plus product.
The following usage assumptions were used to determine the estimated battery life for the Venu 2 Plus. Unless otherwise stated, all default software settings and configurations are assumed for the battery life specifications.
Smartwatch Mode Usage Assumptions | |
Default Display Configuration | |
Notifications per Day | 90 |
Number of Interactions per Day | 160 |
Device-Generated Alerts per Day (Move or Goal Alerts) | 10 |
Hours per Day Outside of Bluetooth Range of Phone | 1 |
Number of Gestures per Day | 200 |
Average Number of Hours per Day Spent Outside1 | 5 |
Watch Face2 | Default |
Display Brightness | Medium |
Display Timeout | Short |
Pulse Ox Mode | Disabled by Default |
Number of Timed Activities | 0 |
Minutes per Day of Voice Assistant/Phone Call Usage | 5 |
Minutes per Day of Music Playback through Speaker | 0 |
Venu 2 Plus Smartwatch Mode Battery Life | Up to 9 days |
Display Always On Mode | |
Average Number of Hours per Day of Sleep3 | 8 |
Display Timeout | Always On |
Venu 2 Plus Smartwatch Mode with Display Always On Battery Life | Up to 2 days |
GPS Mode / GPS Mode with Music Usage Assumptions | |
Number of Interactions per Hour | 10 |
Minutes of Interaction Post-Activity | 1 |
Number of Gestures per Hour | 25 |
Display Timeout During Activity | Short |
Assumed Temperature Range for Battery Life Specifications | 10C – 40C |
Venu 2 Plus GPS Mode Only Battery Life | Up to 24 hours |
Venu 2 Plus GPS Mode with Music Battery Life | Up to 8 hours |
Battery Saver Feature
The Venu 2 Plus also supports a feature called Battery Saver. Enabling this feature changes the behavior of the watch and disables specific functionality to prolong battery life. The table below summarizes the changes that are applied by enabling the Battery Saver feature.
Battery Saver Feature Enabled | |
Number of Gestures per Day | Gesture Mode Disabled |
Average Number of Hours per Day Spent Outside 1 | 5 |
Watch Face | Low Power Watch Face |
Display Brightness | Low |
Pulse Ox Mode | Disabled |
WiFi Usage | Disabled |
Music Playback Through Bluetooth Headphones | Disabled |
Music Playback Through Speaker | Disabled |
Auto Activity Start | Disabled |
Venu 2 Plus Smartwatch Mode Battery Life | Up to 10 days |
1 The Venu 2 Plus utilizes an ambient light sensor to automatically adjust the display brightness to an acceptable level depending upon the level of ambient light. Using the device outdoors in bright environments may reduce battery life.
2 The “default” watch face for the Venu 2 Plus is the watch face present on the device when it is taken out of the box. The Venu 2 Plus is designed to work with a variety of native watch faces as well as compatible Connect IQ watch faces. The usage of watch faces other than the default watch face may impact the battery life experienced in smartwatch mode.
3 The average number of hours per day of sleep is determined by the user-configured bed and wake times (a "sleep period"), not the number of hours the user actually sleeps. During this sleep period, the device's display is turned off. As a result, setting a shorter sleep period may decrease the battery life experienced in display always on mode.
