Clarion M608 Software Update
M608 Improvements "12/28/2018"
- iPod bug fixes
- Other bug fixes
NOTE: Do not perform this software update while operating the vessel/vehicle. Do not interrupt the power of the M608 while the update is in process. Remember to record all the “Settings” prior to performing the update process as, after the update, the settings will be reset to the factory default.
Requirements
- A blank USB memory device (4GB maximum)
- Access to the USB port on the M608.
Preparation
Update
Copy the “M608.hex” file to a blank USB memory device from your PC.
With the M608 powered on, insert the USB memory device into the USB port. The unit will automatically recognize the USB memory device and display USB for 1 second and revert back to tuner. Press and hold BND and SUB buttons simultaneously to start the update process. During the update process unit will display “MCU UPGRADE”.
Once the process has been completed, please remove the USB memory device from the M608.
NOTE: Do not interrupt the update process. The M608 will automatically turn off once update is completed.
Confirm Result
NOTE: If any of the software versions do not match, please perform the software update again.
