How do I Wire my Speakers in 2 Ohm Configuration for my MS-AM702 Zone Amp? (Parallel Configuration)
To wire 2 x 4 Ohm speakers in parallel to present a 2 Ohm load to the MS-AM702 amplifier per channel, simply follow the below diagram showing the Positive terminals from each speaker connected to each other and the same with the Negative terminals. When this is done, simply connect the Positive and Negative wires from the closest speaker to the stereo.
