Changing the Map View on an Automotive Device
Our automotive devices allow you to set the map view to either North Up, Track Up, or 3D.
  • When set to North Up, the map on a device will display North at the top of the screen at all times.
  • If set to Track Up, the direction in which you're traveling will remain at the top of the screen.
Both North Up and Track Up are 2D views. When set to 3D view, the map will take on a 3-dimensional appearance; the direction in which you're traveling will remain at the top of the screen.
To Change the Map View:
  1. Touch Settings
  2. Touch Map & Vehicle
  3. Touch Driving Map View
  4. Touch the desired map view. A preview of your selection appears on the right.
  5. Touch Save to save the change
The map view is now set to your preference.
