Compass icon
With the right settings, you can have a compass icon on the main menu. To set this up, the device must be in Walking/Pedestrian mode. To place the device in Walking/Pedestrian mode, you may simply touch the vehicle icon at the top of the main menu then select Walking.
Once the device is in Walking mode, change your route preference to Off Road and the Map View to Track Up by following the steps below:
- Touch Tools
- Touch Settings
- Touch Navigation
- Touch under Route Preference
- Touch Off Road, and then OK to save the change
- Touch Back once
- Scroll down
- Touch Map
- Touch under Map View
- Touch Track Up, and then touch OK to save the change
Once these settings have been adjusted, touch Where To? and have the device calculate a route to your desired destination. After the route calculates, return to the main menu. You will now see a compass button in the bottom center portion of the screen.
Touching the Compass button will display a compass that shows your current direction of travel along with your current speed and elevation, the time of day, and the distance to your destination.
