Jūs skatāties rakstu, kurš nav pieejams jūsu šobrīd izraudzītajā valodā. Zemāk varat izvēlēties citu valodu.
Customizing Your Alpha 200 Plus and Alpha 300 Menus
The Alpha® 200 Plus, Alpha® 300, and Alpha® 300i dog tracking handhelds have a layout and design where with a click of an icon your entire layout can be customized and redesigned.
Menu Style
The handheld display will default to the first customizable icon on the favorites bar.
From your default screen:
  1. Select Main Menu Alpha home
  2. Select the Set Up icon located on the favorites bar
    Alpha 300 Favorites Bar Set up
  3. Select the Main Menu Set Up
    Alpha 300 Main Menu Set Up
  4. Select Menu Style, by default the Menu Style is set to Grid
    • Grid
    • Small Grid
    • List
Customize Main Menu
From the Main menu
  1. Select the Set Up icon located on the favorites bar
  2. Select the Main Menu Set Up
  3. Select Main Menu
  4. Select the icon you want to remove or change the order of.
  5. Select Add Page to add an icon from one of the three categories
    Applications
    Active Route
    Alarm Clock
    Area Calculation
    Calculator
    Calendar
    Compass
    Dog Compass
    Hunt Fish
    man Overboard
    Map
    Proximity Alarms
    Route Planner
    Set Up
    Share Wirelessly
    Sight N Go
    Stopwatch
    Sun and Moon
    Trip Computer
    Waypoint Averaging
    Xero Locations
    Set Up
    About
    Bluetooth
    Display
    Main Menu
    Map
    Reset
    Routing
    Sensors
    System
    Tones and Alerts
    Tracks
    Wifi
    Where To?
    Addresses
    All POIs
    Anchorages
    Attractions
    Auto Services
    Cities
    Community
    Coordinates
    Currents
    Entertainment
    Facilities
    Fishing Sports
    Food and Drink
    Fuel Services
    Geographic Points
    Hospitals
    intersections
    Lodging
    Marine Services
    Navaids
    Obstructions
    Others
    Photos
    Recent Finds
    Recreation
    Restricted Areas
    Routes
    Shopping
    Tides
    Tracked Devices
    Tracks
    Trails
    Transportation
    Waypoints
To remove or change the order of an application
  1. Select the icon you want to change
  2. Select one of the following options
    • Insert: To Insert an application above the current icon
    • Remove: To remove the application from the Main Menu
    • Move Down/Move Up: To change the order of your applications
Rearranging your Main Menu
You are able to customize your main menu without needing to go into the settings of the handheld.
From the Main Menu
  1. Press/Hold the icon you wish to reorder or remove from your Main Menu Screen
  2. The handheld will Vibrate
  3. Continue to hold the icon as you drag it to a new location on your screen
  4. Release the icon when you get to the desired location.
You are also able to remove icons from this main menu by dragging and dropping the icon to the bottom right corner where the trash icon is located.
Drag Drop Icon
