Recommended Fusion® Subwoofer Enclosure Volumes
All Fusion® subwoofers have an optimal enclosure size that is based on a specific tuning point.
To calculate volume for a given enclosure, a calculator and tape measure will be needed to apply the formula.
In inches, Length x Width x Depth divided by 1728 = volume in cubic feet
In centimeters, Length x Width x Depth divided by 1000 = volume in liters
In liters, volume divided by 28.317 = volume in cubic feet
Always account for the volume of the subwoofer that will be inside the enclosure. When calculating the volume of an enclosure, use the inside dimensions to account for the thickness of the material being used.
Fusion subwoofer enclosure recommendations
Subwoofer model | Sealed enclosure size | Ported enclosure size | Port diameter | Port length |
FM Series 10" Subwoofer | 40 liters or 1.41 cubic feet | None | None | None |
XS Series 10" Subwoofer | 40 liters or 1.41 cubic feet | None | None | None |
Signature Series 10" Subwoofer | 27 liters or 1.41 cubic feet | 45 liters or 1.6 cubic feet | 104 millimeters or 4.1 inches | 256 millimeters or 10.3 inches |
Signature Series 12" Subwoofer | 60 liters or 2.12 cubic feet | 250 liters or 8.83 cubic feet | 102 millimeters or 4 inches | 127 millimeters or 5 inches |
