How to update the Rv-bbt601 Dock
To download software updates for the Dock you will need a USB flash drive that is 4GB to 32GB. The flash drive will need to be initialized by the Dock. This allows the Garmin Express™ software to recognize the USB flash drive and deliver the correct software for the Dock. This process is outlined below.
  1. Turn on the vehicle, and place the RV HUB Remote in the RV HUB Dock. The dock must be receiving power to prepare the USB flash drive.
  2. Locate the media USB port in your vehicle.
  3. Plug the USB flash drive into the USB port.
  4. On the Remote Select Music
  5. Select Settings
  6. Select Update
  7. Select Create Card, a message appears when the dock has finished preparing the USB flash drive to receive the software updates.
  8. After the USB flash drive is prepared, you should remove the flash drive and download the software updates using Garmin Express (Downloading Software Updates to the Prepared USB Flash Drive).
