Why Do I Not Have Map Options in My Navionics Boating App Menu?
Map Options are available and work along with the Navionics® charting within your Boating app.  If you have Nautical Chart or SonarChart™ selected as your map layer, you can find Map Options under your Menu.
If you have the government (GOVT) maps chosen on your screen you will not have the ability to use or change Map Options, as this information is taken directly from the government charts. Because the government charts are not set up in the same way our charting database is, our Map Options will not work along with these charts.
Related
