Skipping Shaping Points on Automotive Devices
Shaping points are waypoints that can be added to a custom route to direct an automotive device to use specific roads when navigating the route. For information on shaping points, see How to Change a Waypoint into a Shaping Point on an Automotive Device
Only shaping points can be skipped. Your device will not skip waypoints in your custom route.
To Skip a Shaping Point:
- Continue on the desired route until you merge back to your custom route
- Do this regardless of the direction of the shaping point
- The device will recalculate and continue to navigate to your upcoming waypoints or shaping points
