Customizing the Sounds on the Upland Beeper
The Delta Upland™ Beeper can operate under a variety of sound combinations or modes.
These include a series of beeps when the dog is hunting and a hawk scream or a beep when on point:
  • HUNT Mode – The Beeper sounds every 4 seconds while the dog is moving.
  • POINT Mode – The Beeper sounds once every second while the dog is on point. The hawk scream sounds every five seconds.
  • HUNT Mode and POINT Mode can be set with eight pre-set combinations that you select.
To check the current Beeper setting:
  1. Power on the Beeper
  2. To decrease the sound, place your thumb over the speaker hole
  3. To hear the HUNT setting, gently shake the Beeper (to simulate a running dog)
  4. To hear the POINT setting, hold the Beeper still.
To select a specific Beeper mode:
  2. Press and hold Power
  3. Wait until both LED lights blink three times
  4. Release Power (The LED lights will indicate the current setting*)
  5. Tap Power to cycle to the desired mode
  6. Save your selection:
    1. Press and hold the Power Select button
    2. Wait until both LED lights flash three times
    3. Release Power
The Beeper will now operate in the mode you have selected.
* Mode Setting Cycle chart
