Incident Notifications / Emergency Assistance Contact Setup and Usage
WARNING! The device allows you to send your location to an emergency contact. This is a supplemental feature and should not be relied upon as a primary method to obtain emergency assistance. The Garmin Drive™ app does not contact emergency services on your behalf.
The Incident Detection and Notification feature, also known as Emergency Assistance, will send a message and your location to your Emergency Assistance contact if an incident is detected on your zūmo® XT GPS navigator. This can be useful if you are not able to call or send a message in an emergency situation. See Incident Detection and Notifications.
What Are the Requirements to Use Emergency Assistance?
  1. Power Connection
    • The zūmo XT must be connected to external power using the motorcycle mount. A USB cable should not be used.
  2. Bluetooth Connection and Settings
    • The zūmo XT must be connected via Bluetooth to your phone and a headset to set up and use the incident notification feature.
    • The zūmo XT must be connected via Bluetooth to the Garmin Drive™ app on your phone.
    • The smartphone must be in an area of network coverage where data connectivity is available.
    • Phone Calls must be enabled on the zūmo XT.
      1. Select Settings
      2. Select Wireless Networks
      3. Verify the Phone calls option is enabled (checkmark) for your phone
    • Incident Detection and Incident Notification must be enabled on the zūmo XT:
      1. On the zūmo XT, select Settings
      2. Select Driver Assistance
        • Tap on Automatic Incident Detection to enable (checkmark).
        • Tap on Incident Notification (see the steps below to set up an incident contact).
          • Tap onIncident Detection SMS to enable (checkmark)
          • Tap on Save
  3. Incident/Emergency Contact
    • An incident contact must be set up on the zūmo XT using the process outlined in the steps below.
    • The incident contact must be an existing contact on the smartphone paired with the zūmo XT device.
      • You are asked to select a contact shown on the zūmo® XT GPS navigator from your phone's phonebook when setting up incident notifications. The zūmo XT will only display approximately 35 contacts. (See the steps below to access more contacts to choose from).
      • The zūmo XT has a limit of 500 contacts. Having over 500 contacts may result in searches appearing differently or incomplete. For example: Some searches may not show the whole list or the list may not appear in alphanumeric order.
    • If you do not set up an incident contact, the zūmo XT device will automatically display the nearest address or geographic coordinates, if available, when it detects an incident.
      • Contacts must accept and agree to receive messages before becoming an active contact.
    • The incident contact's phone must be capable of receiving text messages (standard text messaging rates may apply) and/or email.
Setting Up an Incident/Emergency Contact
1. Touch Settings
2. Touch the down arrow on the left, then touch Driver Assistance
3. Touch the down arrow, then touch Incident Notification
4. Touch Continue
  • If prompted, first allow permissions to allow phone contacts to be synced for usage with the incident notification feature.
5. If the desired contact is listed, select it and skip to step 7.
  • If the contact is not listed, touch the magnifying glass in the upper left corner.
6. Type the contact name
7. Touch the contact name, then touch Select
8. Touch Next
9. Type Your Name
10. Touch Next
11. Touch OK
  • A text or email will be sent to your selected emergency contact (see example below)
  • The contact will now be notified in the event of an incident.
  • To remove a contact see the steps below, 'Removing Emergency Contacts'
12. Touch Save
To change the emergency contact, select the contact name and repeat steps 5-12 above.
1. Touch the menu in the upper left
Restore Menu.
2. Touch Restore
Restore 1
3. Touch Yes
Restore Yes
The saved contact will now be deleted.
