Access the menu of the device.
Select Settings (Edge 540 Series, skip to Step 3.)
Select Sensors.
Locate and select your paired power meter pedals.
Select Remove > Yes.
Select Add Sensor > Search All from Sensors.
Select Power.
Pair the power meter again.
What Are Cycling Dynamics?
Cycling dynamics are metrics and visual displays based upon data recorded by compatible dual sensing power meter pedals. This data is then transmitted and displayed on compatible Garmin Fitness and Outdoor devices. Cycling dynamic data can also be analyzed in your Garmin Connect™ account by uploading and viewing the details of the activity.
Cycling Dynamics Include:
Cycling Dynamics Requirements
In order to record cycling dynamics data during your ride, you must meet the following requirements:
You own a dual-sensing Rally, Vector 3, or a compatible third party power meter set.
Rally™ RK200, Rally™ RS200, or Rally™ XC200.
Vector™ 3 (Vector 3S is not a dual-sensing power meter pedal).
Check with the manufacturer to see if a third party power meter is compatible with Cycling Dynamics.
Your pedals are paired to your head unit or watch via the ANT+ channel.
Cycling dynamics data will not transmit via BLE (Bluetooth Low Energy).
To check, view Sensors > Power Meter > Connection Type.
- If you have the option, simply select ANT+ and the channel will switch from BLE to ANT+.
Pairing Pedals to the ANT+ Channel
If you need to unpair your pedals in order to pair them via ANT+, select one of the options below to reveal instructions. Otherwise, refer to your owner's manual.
Select
Select Sensors.
Select the paired power meter.
Select Remove.
Select Yes.
Select Add Sensor.
Select Search All from Sensors.
Select Power.
Hold UP/MENU (middle left button) to access the main menu.
Scroll to or select Settings.
(Optional) on some watches, select Connectivity.
Select Sensors & Accessories.
Select Remove.
Select Yes.
Select Add New.
Select Search All from Sensors & Accessories to pair the power meter again.
Garmin Devices Compatible With Cycling Dynamics
Choose an option below to reveal a list of devices.
Edge® 520
Edge® 520 Plus
Edge® 530
Edge® 540 | Edge® 540 Solar
Edge® 820
Edge® 830
Edge® 840 | Edge® 840 Solar
Edge® 1000
Edge® 1030 | Edge® 1030 Plus
Edge® 1040 | Edge® 1040 Solar
Edge® 1050
Edge® Explore 21
Edge® MTB
1The Edge Explore 2 will detect Cycling Dynamics and display after the activity is saved and uploaded to Garmin Connect, but will not be able to display them live on the unit during the activity.
D2™ Mach 1 | D2™ Mach 1 Pro
Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
Descent™ G2
Descent™ Mk2 | Descent™ Mk2S | Descent™ Mk2i
Descent™ Mk3 | Descent™ Mk3i | Descent™ Mk3i
Enduro™
Enduro™ 2
Enduro™ 3
epix™ (Gen 2) Porsche Edition | epix™ (Gen 2) Sapphire
epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
fēnix® 5S | fēnix® 5 | fēnix® 5X
fēnix® 5 Plus | fēnix® 5S Plus | fēnix® 5X Plus
fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
fēnix® 7 - Standard Edition | fēnix®7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
fēnix® E
fēnix® Chronos
Forerunner® 745
Forerunner® 935
Forerunner® 945 | Forerunner® 945 LTE
Forerunner® 955 | Forerunner® 955 Solar
Forerunner® 965
Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
Instinct® 3 - AMOLED | Instinct® 3 - Solar
Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar
Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
quatix® 5 | quatix® 5 Sapphire
quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
quatix® 7 Pro | quatix® 7 Sapphire Edition | quatix® 7X Solar Edition
tactix® 7 - AMOLED Edition | tactix® 7 Standard Edition | tactix® 7 Pro Edition | tactix® 7 Pro Ballistics Edition
tactix® 8 - AMOLED | tactix® 8 - Solar
tactix® Charlie
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
Garmin Devices Compatible With Power But Not Cycling Dynamics
Choose an option below to reveal a list of devices that will pair and display power data but not cycling dynamics data.
Edge® 130
Edge® 130 Plus
Edge® 500
Edge® 510
Edge® 705
Edge® 800
Edge® 810
D2™ Bravo
D2™ Charlie
D2™ Delta S | D2™ Delta | D2™ Delta PX
Descent™ MK1
fēnix® 3 | fēnix® 3 HR | fēnix® 3 Sapphire
Forerunner® 310XT
Forerunner® 910XT
Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
Forerunner® 265 | Forerunner® 265S
tactix® Bravo
quatix® 3
For more information about connecting sensors, see - Best Practices for Connecting Sensors to Your Garmin Device.
