What Is the Primary Race Glance on My Garmin Watch?
The Primary Race glance helps tailor your training to prepare you for an upcoming race event. Your Training Status, HRV Status, and Training Readiness all contribute to managing your training volume and intensity, getting you ready for race day. To find out if your watch is compatible with the Primary Race glance, search your owner's manual for "Glances."
To view different topics for this feature, select the navigation option below:
What Data Will The Glance Display?
Some features you may see on this glance include (some watches may not support all features):
  • Race date countdown
  • Event date and time
  • Assistance with training volume and intensity
  • Weather and elevation data for the event
  • Optional PacePro™ race strategy or time/pace goals
  • Personalized Daily Suggested Workouts tailored to your primary race event
  • Predicted finish time for 5K, 10K, half marathon and full marathon distances
Find or Create an Event
To use the Primary Race glance, you will need to find or create a race event in your Garmin Connect™ account on your calendar. Once an event has been added to your Garmin Connect Calendar, and you have synced your watch, the Primary Race glance will automatically be added to the widget or glances loop on the watch.
NOTE: While ultra marathon events can be selected as a race event, the Personalized Daily Suggested Workouts were not designed for ultra marathons and may not fit your training needs.
To check if your watch supports this feature, see your owner's manual.
Garmin Connect App
  1. Open the Garmin Connect app.
  2. Select Calendar Icon from GC 5 Calendar.
  3. Swipe to find the month of your race event.
  4. Select the day.
  5. Select Three Vertical Dots in the upper right corner.
  6. Select Add Event.
  7. Select one of the options:
    • Find an event.
    • Create an event.
  8. Add the event to your calendar by filling in the fields.
    • If you have more than one event on your calendar, you will need to select a primary event.
  9. The event will be sent to your watch during the next sync.
Garmin Connect Web
  1. From a web browser, sign into Garmin Connect.
  2. Select Calendar icon and the word Calendar.
  3. Select the date of your event.
  4. Select the date.
  5. Select Event Flag Icon Event
  6. Select one of the following:
    • Find an event.
    • Create an event.
  7. Add the event to your calendar by filling in the fields.
  8. The event will be sent to your watch during the next sync.
Back to Top
How Do I Assign a Primary Race Event?
You will be asked to select Priority for the following activity types: Running, Trail Running, Cycling, Gravel (Unpaved) Cycling, Mountain Biking, and Multisport.
NOTE: The Primary Race glance on the device will only show Run or Bike event types that are set to Primary or Supporting priority. The glance can also show primary or supporting triathlon events only on devices that support the Garmin Triathlon Coach. To manage your event's priority, see the steps below.
Garmin Connect App
  3. Select the date of the event you wish to set as your primary race event.
  4. Select the event name.
  5. Select the Training tab.
  6. Select Event Goal.
  7. Select Finish the event.
  8. Place a checkmark next to event.
  9. Select Done.
Garmin Connect Web
  3. Select your existing primary race event.
  4. Select Grey gear icon.
  5. Select Manage Event Priority.
  6. Select the event you wish to set as your primary race event.
  7. Select Finish.
  8. Select OK.
Back to Top
How Do I Add a PacePro Strategy to My Race?
The PacePro feature offers guidance on pacing during your run. In order to add a PacePro strategy to your race, you need to have a course for the event. See Related for more information on PacePro and courses. Select your platform below for instructions to add a PacePro plan to your race.
Garmin Connect App
  6. Select PacePro Strategy.
  7. Enter your goal information.
  8. Review the plan and make any changes.
  9. Select Save.
Garmin Connect Web
  3. Select your event.
  4. Select Add a PacePro Strategy.
  5. Enter your goal information.
  6. Review the plan and make any changes.
  7. Select Save
Back to Top
"An Event Has Been Deleted" Message
If you added someone else's race event to your calendar, instead of creating your own event, you will receive 'An Event Has Been Deleted" message when the original owner deletes it. To avoid this from happening in the future, we recommend creating your own race event and setting it to private.
Back to Top
What Is a Verified Source?
A Verified Source is an event that was created by a Garmin partner and is flagged as an official event. A Verified Source event can be modified or deleted but only by that specific owner.
Back to Top
Primary Race Glance Tutorial
Back to Top
Related
