FiX®: Differences from CleanSweep® CL441dsp
Like its predecessor the CleanSweep® CL441dsp, the FiX® 82 and FiX® 86 are OEM integration DSP's that correct any factory equalization, providing a completely flat audio signal. The FiX® also adds new features and control options when compared to the CleanSweep® CL441dsp, as can be seen in the chart below.
FiX® 82 | FiX® 86 | CleanSweep® CL441dsp | CleanSweep® CL-SSI | |
Calibration Track | Play track before pressing the Calibrate button | Play track before pressing the Calibrate button | Play track after pressing the Calibrate button | N/A |
Initiate Calibration | Press and hold the Calibrate button for 5 seconds | Press and hold the Calibrate button for 5 seconds | Press and release the Calibrate button | N/A |
Inputs | Eight channels: 1/2, 3/4, 5/6 (not channel specific), 7/8 (sub only) | Eight channels: 1/2 & 3/4 (Front), 5/6 (Rear), 7/8 (sub) | Four channels: LF, LR, RL, RR (channel specific) | A (Front), B (Rear), C (Sub) |
Band Specific Inputs | 1/2 (midrange for best auto turn-on results) | 1/2 (midrange for best auto turn-on results) | N/A | Input C (sub only) |
Channel Summing | Up to 4-way system | Up to 3-way system | N/A | Up to 3-way system |
Output Level Adjustments | Automatic | Automatic | N/A | Manual |
OEM Time Delay Correction | Automatic | Automatic | N/A | N/A |
Status LED's | Two for input status, Two for calibration status (all with multi-level reporting) | Two for input status, Two for calibration status (all with multi-level reporting) | Four (4) LED’s, one for each channel | Signal ‘Too Low’, ‘Too High’ and ‘Just Right’ |
Outputs | Analog: 2-channel (RCA) Digital: Optical S/PDIF (Toslink) | Analog: 6-channel (RCA) labeled Front, Rear, Sub | Analog: 2-channel (RCA) | N/A |
Remote Control | DRC-100 (not included) | DRC-100 (Not Included) DRC-200 (Not Included) | CL-VOL-ASSY (included) | N/A |
Remote Control Functions | Master volume, Handsfree optimization, Input clipping indicator | Master volume, subwoofer control (DRC-200), Handsfree optimization, clipping indicator | Master volume, OEM source/AUX switcher or mute/un-mute | N/A |
Turn On Options | Remote, DC Offset, Signal Sense (+12VDC Switched always connected) | Remote, DC Offset, Signal Sense (+12VDC Switched always connected) | Remote, Signal Sense (+12VDC Switched always connected) | N/A |
