Quarter-Turn locking Collars for Discontinued Garmin Chartplotters
Some discontinued models require a quarter-turn locking collar. Below are the part numbers for the Quarter Turn Locking Collars. Online retailers may still have stock available.
11mm Cables
  • Quarter Turn Locking Collar - K00-00494-01
    • 7-pin power cable (any)
    • 2-pin power cable GPSMAP 4xxx, and 5xxx series (verify quarter-turn)
    • Power cable GHC 10, GHP 10 ECU
    • The coiled cable on GHS 10
    • 6-Pin transducer cable
    • VHF 200 fist microphone
    • VHF active speaker
    • VHF 300 power cable
    • All Garmin Marine Radar systems1
1 check for threaded or quarter turn port. Depending on the manufacture date, all Garmin radars could contain a threaded or a quarter-turn connector. Confirm which collar is needed before placing an order.
2 This only applies to GHP 10 ECUs packaged in the Reactor 40 Core packs
14.5 mm Cables
  • Quarter Turn Locking Collar - K00-00494-21
    • 19-pin power cable  GPSMAP 4x0 and 5x0 series
    • NMEA 0183 cable GPSMAP 4xxx, and 5xxx series (verify quarter-turn)
    • Interconnect Cable - GHP 10 - CCU to ECU
18mm Cables
  • Quarter Turn Locking Collar - K00-00494-11  -  No long available
    • Video cable - GPSMAP 3xxx, 4xxx, and 5xxx series
