Lily Battery Life Assumptions
The battery life of your Garmin watch may be affected by how you use the watch. The information in the tables below is intended to outline the conditions used to determine the battery life specifications. Usage beyond what is listed below, or usage of features not listed, may result in reduced battery life. The information presented below is presented as a general guide for reference only on the Lily® - Classic Edition and Lily® - Sport Edition product.
The following usage assumptions were used to determine the battery life for Lily. Unless otherwise stated, all default software settings and configurations are assumed for the battery life specifications.
Lily Smartwatch Mode - Default Display Configuration
Notifications per Day90
Number of Interactions per Day80
Device-Generated Alerts per Day9
Hours per Day Outside of Bluetooth Range of Phone1
Number of Gestures per Day80
Average Number of Hours per Day Spent Outside12
Watch Face2Default
Display Brightness & TimeoutDefault Settings
Pulse Ox ModeDisabled by Default
Number of Timed Activities0
Battery LifeUp to 5 Days
1 Lily utilizes an ambient light sensor to automatically adjust the display brightness to an acceptable level depending upon the level of ambient light. Using the device outdoors in bright environments may reduce battery life due to increased display brightness.
2 Lily’s “default” watch face is the watch face present on the device when it is taken out of the box. Lily is designed to work with a variety of native watch faces. The usage of watch faces other than the default watch face may impact the battery life experienced in smartwatch mode.
