Reduced Speed Tone Alert
The Speed Limit Exceeded alert is a feature available on your Tread to notify you when approaching an area where the speed limit has been reduced. These alerts are present during general navigation, with an active route or otherwise. The feature should be available anywhere the posted speed limit changes.
To Enable or Disable Speed Limit Reduction Alerts:
1. Touch Settings
- SxS Edition
- Overland Editions
2. Touch Driver Assistance
3. Touch Driver Alerts
4. Touch the box next to Speed Limit Exceeded
- A checkmark indicates the feature is enabled
- Touching the box again to remove the checkmark will disable the feature
Repeat the steps above to enable or disable the Speed Limit Reduction alert.
See Wireless Map and Software Update Instructions if you don't have this option on your device.
