Using the currency converter on a nüvi® 200 and 205 series device
There may be times you will want to use the currency converter on your nüvi® 200, 205 series device.
To use the currency converter:
- Touch Tools
- Touch Unit Converter
- Touch Conversion
- Touch Currency
- Touch OK
- Touch a box with a currency listed
- Touch the desired currency
- Touch OK to save the change
- Touch the field adjacent to or below the currency you would like to convert
- Enter the amount
- Touch Done
The currency conversion will display automatically.
To update the exchange rate on the device:
- Open the currency converter
- Set the converter to the two desired currencies
- Touch Update
- Enter the current exchange rate for the currencies listed
- Touch Save
The exchange rate for the currencies selected will now be set. To reset the exchange rate, or to set the exchange rate for other currencies, repeat the above steps.
