How do I Connect Wiring to my Signature Series Sport Speaker for LED Lighting?
Sports Model LED Wiring.
Connecting the LED wires to the Sports model speakers.
- Note: This feature is available only on the Sports model speakers.
- You can control the color of the LEDs by the polarity of the LED wires Using the hex key, loosen the screws on the wiring terminals on the back of the speaker.
- Connect the Black and Red wires to the terminal according to the preferred LED color.
- Blue: Black wire to negative (-) and Red wire to positive (+).
- White: Black wire to positive (+) and Red wire to negative (-).
- Using the hex key, tighten the screws on the wiring terminals.
- Push the wire into a retaining clip to relieve the tension on the wire.
- Connecting the Sports model speakers' LED wires to power.
- All 12VDC wiring to the LEDs must be fused at the power source end of your cable using a 3A fuse.
- The Red power (+) wire should be connected to a 12VDC source through an isolator switch or circuit breaker to turn the speaker LEDs on and off.
- You can use the same isolator or circuit breaker controlling the power supply to your stereo, which allows you to turn the LEDs and stereo on and off at the same time.
- If it is necessary to extend the Red and Black wires include with the speakers, you should use 20 AWG (0.5 mm2) or thicker wire.
- Route the Red power (+) and Black ground (-) wires to the battery and speaker.
- Connect the Black wire to the negative (-) battery terminal.
- Connect the Red wire to the positive (+) terminal through a 3A fuse and isolator switch or circuit breaker.
