- Double-click My Computer
- Right-click the Garmin drive
- Click Explore
- Click Tools
- Click Folder Options
- Click the view tab
- Select the option "Show hidden files and folders"
- Click Yes
- Click OK
Garmin Locks Up With a Long Noise, Tone or Continuous Beep When Powering Down
If a device is locking up and has a long noise, tone or continuous beep when powering down and can only be stopped by removing the batteries, hidden data has been placed from a computer on the microSD card. Mac computers add hidden files and/or folders to mounted devices.
The information and steps in this article apply to the following devices:
- eTrex Legend® Cx and HCx
- eTrex Venture® Cx
- eTrex Vista® Cx and HCx
- GPSMAP® 60Cx and 60CSx
- GPSMAP® 76Cx and 76CSx
- Rino® 520HCx and 530HCx
Resolution
These unused or hidden files and/or folders need to be deleted from the microSD card. As the issue is caused by a Mac computer, removing the files needs to be done on a Windows computer. Examples of these folders are: Trashes and Spotlight-V100
To delete the files and/or folders, the device needs to be in USB mass storage mode.
Placing the Device Into USB Mass Storage Mode
- Connect device to computer via USB cable
- Go to device Main Menu
- Select Setup
- Select Interface
- Select USB Mass Storage Mode
The device is now in USB Mass Storage Mode.
Deleting the Unused or Hidden Files and/or Folders
- A window should have opened on the computer desktop displaying Removable Disk at the top. Open the Garmin folder that displays
- Note: Do NOT delete the following: Garmin (folder), gmapsupp.img (file), gmapsupp.unl (file) or gmapsupp.gma (file)
- These files and folders contain supplemental mapping and/or track data. Deleting these in error will cause the mapping, or tracks to be erased or un-viewable
- Delete any other files and/or folders from the microSD card not listed in the note above
- Some of these files or folders may be hidden and need to be revealed
Select your operating system below for steps -
- Click on Start icon
- Click on computer
- Double-click the Garmin drive
- Click Organize
- Click on Folder and Search options
- Click View tab
- Click OK
- Press the Windows key + E
- Click View
- Click Options
- Click OK
- Click View
- Click Options
- Click View again
- Select the option "Show hidden files, folders and drives"
- Click OK
- Disconnect the device from the computer and power it on
The device should no longer beep when it is turned off.
