(2022) Service Bulletin 22013 Rev A: G5 Backup Battery Discharge
PRODUCTS AFFECTED:
Garmin G5 Electronic Flight Instruments (011-03809-00) with the following serial numbers are affected:
https://support.garmin.com/aviation/faq/3PZHfyHuHk4mBgBhsEMZN9/
COMPLIANCE:
Mandatory: This service bulletin must be complied with no later than February 28, 2023.
PURPOSE:
The affected G5s can discharge the G5 backup battery to 0% if airframe electrical power is not applied for multiple weeks.
WARNING
Verification of good battery status is required before flight into IMC as described in the Airframe Flight Manual Supplement (190-01112-13). See also G5 Electronic Flight Instrument Pilot’s Guide for Certified Aircraft (includes the GFC 500) (190-01112-12). See also G5 Electronic Flight Instrument Pilot’s Guide for Non-Certified Aircraft (includes the GFC 500) (190-02072-00).
NOTE
Garmin recommends G5 Software Version 8.00 (Garmin STC Service Bulletin 22011) that provides improved detection and indication of G5 backup battery failure.
DESCRIPTION:
This service bulletin contains instructions to return the affected product to Garmin. See bulletin linked below for details.
