Arrival Time Showing Dashed Lines Instead of the Actual Time When Navigating
If the Arrival Time on the Garmin chartplotter only shows dashed lines when navigating to a destination, the arrival time to the destination exceeds 24 hours. If the arrival time is more than 24 hours, the device cannot display this information correctly.
Change the Arrival Time data field to display Time To Destination. This data field will show the appropriate time (hours and minutes) to reach your destination.
For example, if the trip is estimated to take 26 hours and 35 minutes to reach the desired destination, the Arrival Time data field will display dashed lines. The Time To Destination will show 26:35, as expected in the same scenario. If the Time To Destination is under 24 hours, use the Arrival Time data field to display the appropriate information.
For additional information regarding data fields, refer to the Owner's Manual for the device.
