Customization Options for Garmin Instinct 3 Solar Series Watch Face
The Instinct® 3 - Solar series watches offer 11 pre-loaded unique watch faces, with an inverted color option of each. Additionally, each watch face has the ability to customize what data or symbols are displayed. The selected watch face may change what options are available to be customized or how the data appears. Depending on the watch face, you will have between two and seven different data customization options. The Instinct 3 - Solar series offers a unique display with a dial screen in the top right corner to isolate different data options. For more information on the Dial Screen options, select Dial Screen below.
Customizing the Watch Face
  1. From the watch face, hold UP/MENU (middle-left button).
  2. Select Watch Face.
  3. Press UP/MENU or ABC (lower-left button) to navigate your saved watch faces.
    • Select Add + to create a new watch face.
  4. Press GPS (upper-right button) to select a watch face example.
  5. Press GPS, then select an option:
    • Select Apply to activate the watch face.
    • Select Data to change what data options appear.
    • Select Color to invert the color of the text and background.
    • Select Delete to remove the watch face.
  6. Select Apply to save changes.
For more information and examples of the different watch faces and data customization options, select the options below.
Available Watch Face Templates
Watch Face Examples
Preloaded Watch Face Templates
Watch face example 1 with time and data
Watch face example 2 with time and data
Watch face example 3 with time and data
Watch face example 4 with time and data
Watch face example 5 with time and data
Watch face example 6 with time and data
Watch face example 7 with time and data
Watch face example 8 with time and data
Watch face example 9 with time and data
Watch face example 10 with time and data
Watch face example 11 with time and data
Deleting a Saved Watch Face
You can have up to ten saved customized watch faces. After you have saved 10 watch faces, if you want to create a new watch face, you will need to delete one of your saved customizations in order to add a new  customized watch face. Deleting a saved watch face does not delete the watch face template from your watch.
  3. Press UP/MENU or ABC (lower-left button) to scroll through your saved watch faces.
  4. Press GPS (upper-right button) to select the face that you want to delete.
  5. Select Delete.
Dial Screen
The following options are available on most of the watch faces. Many of these options can be viewed on the other data fields outside of the dial screen.
Moon, battery, phone, and clock symbols.
Status Icons
Displays current battery life, if the watch is set to Do Not Disturb, if an alarm is set, and if it is paired with a phone.
Rectangle battery symbol with small lines indicating battery amount.Battery Life
Displays the remaining battery life.
Day of the week abbreviation above numbers.Weekday and Day
Displays the current calendar date and day of the week.
Month abbreviation above numbers.Day and Month
Displays the current calendar date and month.
Heart symbol above numbers.Heart Rate
Displays the reading taken from the optical heart rate sensor (OHR).
OHR sensor must be on to get a reading.
Two footprints above numbers.Steps
Displays daily step count.
Triangles above numbers.
Elevation
Displays your current elevation.
Horizontal arrow above numbers.Barometer Trending Line and the Barometer Reading
Will display the current barometer pressure in millibars.
The barometer trend line considers the last 6 hours, broken into two 3 hour segments. If there is a 2.3 millibar change over the 3-hour segment, the line will curve up or down depending on the direction of change.
Setting sun symbol on top of numbers.Sunset/Sunrise
Displays Sunset/Sunrise time.
Square text bubble over numbers.Notifications
Displays the number of notifications.
Notifications number won't be cleared until they are cleared from the phone.
Square calendar symbol over two small dashes.Calendar Notifications
Display the number of calendar notifications for the day.
Word NOW over number with degree symbol.
Weather
Displays the weather information received from the Garmin Connect App.
Flame symbol over numbers.Calories Burned
Displays total calories burned for the day.
Arrow and line representing stairs above a number.Floors Climbed
Displays floors climbed for that day.
Circle and lines and numbers.Intensity Minutes
Displays the number of intensity minutes generated for the week.
Circle with lines inside above numbers and percentage symbol.Pulse Ox
Displays the last pulse oximeter reading.
Person running over numbers.Weekly Run Total
Displays distance of all running activities for the week, except Trail Run.
Person cycling over numbersWeekly Cycling Total
Displays distance of all cycling activities for the week.
Letters UTC above numbers.Universal Time Coordinated
Displays Universal Time Coordinated (UTC).
UTC is the successor to Greenwich Mean Time (GMT).
Sun symbol with rectangles around the edge.
Solar Intensity1
Displays current solar intensity and fills in as solar intensity increases.
Sun symbol with white and black background.
Sun Position
Displays the current position of the sun.
Moon with light and dark
Moon Phase
Displays the current phase of the moon.
There are are a number of watch faces that offer a small graph data field.
Small Graph Watch Face
Some watch faces offer the option to display certain types of data as a graph. Not all watch face templates will have graph data fields as an option.
Line graph of barometer data with barometric pressure.
Barometer Graph
Displays current barometric pressure and graph showing the change of barometric readings over the last four hours
Line graph of elevation data with current elevation number.
Elevation Graph
Displays current elevation and graph showing the change of elevation readings over the last four hours
Line graph of heart rate data and current heart rate number.
Heart Rate Graph
Displays current heart rate in beats per minute and graph showing heart rate readings over the last four hours
Line graph of solar charging data with battery estimate.
Solar Graph1
Displays graph of changes in solar intensity over the last six hours
Line graph of daily step data with footprint step symbol and number of steps.
Steps Graph
Displays total step count for the day and a bar graph showing steps generated over the course of the day by hour
For more information on the Garmin Instinct 3 - Solar series watches, refer to your owner's manual.
