Install US TOPO Version 3.00, 3.01, or 3.02 to the Hard Drive in Windows
By design, US TOPO version 3.00, 3.01, and 3.02 require the original CDs to be in the disc drive to function. This is because the map image files are not copied to the hard drive during installation.
Important Items to Note Regarding the Alternative Method Below
- The alternate method below is provided as a possible workaround and is not supported by Garmin.
- This process will not work on a Mac computer, only Windows.
- For Mac users, the installer for the disc set does not function in a 64-bit operating system. If you have updated your Mac to 64-bit and the discs no longer operate, there is no workaround and a new map will need to be purchased.
- BaseCamp™ software will not display these TOPO maps unless the alternate install has been performed.
Alternative Method for Installing the Disc Set to the Hard Drive
If necessary, the maps may be installed to the hard drive using the unsupported alternative method below.
