Map Text Size Options on Outdoor Handhelds
Most outdoor handhelds have options to adjust map text size.
If you are not near any of these items, there may not be a noticeable change when changing the text size. Depending on the specific map(s) you have and what is enabled, some of these items may remain the same. You can pan the map around to one of these items to see if there is a difference between its size and other items after changing the text size.
- Map Points
- Business POIs (Points-of-Interest)
- Geographical POIs
- Navigation Aids (Marine)
- Tide Stations
- Airports
- User Waypoints
- Street Label
- Land Cover
- Geographical Areas
- Parks
- Contour Lines
This list does not include all items that will change when adjusting these map text size options. Every map categorizes items differently, and changes vary depending on your map and handheld model.
For steps on how to adjust these map text size options, see your handheld's owner's manual.
