Recording a Track on the Dakota 10 and 20
A track is a recording of your path. The track log contains information about points along the recorded path, including time, location, and elevation for each point. To record a track on the Dakota™ 10 or Dakota™ 20 follow the directions below.
Recording a Track
  1. Touch Setup.
  2. Touch Tracks
  3. Touch Track Log
  4. Touch Do Not Record; Record, Do Not Show; or Record, Show On Map
    NOTE: If you select Record, Show On Map, a line on the Map page indicates your track.
Clear Current Track Log
  1. Touch Setup
  2. Touch Reset
  3. Touch Clear Current Track
  4. Touch Yes.
