Customizing the Watch Face on the MARQ Collection (Gen 2)
MARQ® Collection (Gen 2) watches offer the ability to customize what data is displayed on the watch face. The selected watch face may change what can be customized, what options are available, or how the data appears. The instructions below are for customizing the pre-loaded watch faces. For instructions on customizing watch faces that have been downloaded from the Connect IQ Store, see - How to Customize a Watch Face Through Connect IQ™ Store.
  1. From the watch face, hold Menu.
  2. Select Watch Face.
  3. Press Up or Down to navigate to other watch faces.
    • Select Add New if you would like to start from a minimal watch face.
  4. Press Start/Stop, then select an options to customize.
    • Select Dial to change the style of the numbers for the analog watch face.
    • Select Hands to change the style of the hands for the analog watch face.
    • Select Layout to change Layout of fields.
    • Select Seconds to change the style of the seconds for the digital watch face.
    • Select Data to change what data options appear.
    • Select Accent Color to change the color that is adjustable on the watch face.
    • Select Data Color to change the color of the data that appears on the watch face.
    • Select BKGD Color to change the background color.
  5. Select Apply to save changes.
For more information and examples of the different watch faces and data customization options, select the options below.
Available Watch Faces
When customizing the data on a watch face, you can touch specific areas of the display to change what data is shown.
Watch FaceTouch Areas
MARQ Adventurer (Gen 2)
MARQAdventurer
MARQAdventurerTouch
MARQ Athlete (Gen 2)
MARQAthleteGen2
MARQAthleteGen2Touch
MARQ Aviator (Gen 2)
MARQAviator
MARQAviatorTouch
MARQ Captain (Gen 2)
MARQCaptain
MARQCaptainTouch
MARQ Golfer (Gen 2)
MARQ Golfer
MARQ Golfer (Gen 2)
MARQGolferTouch
epix watch face example 1epix watch face example 1 touch
MARQ2MARQ2Touch
MARQ3MARQ3Touch
MARQ5MARQ5Touch
MARQ6MARQ6Touch
MARQ7MARQ7Touch
MARQ8MARQ8Touch
epix watch face example 8epix watch face example 8 touch
epix watch face example 9epix watch face example 9 touch
MARQ9MARQ9Touch
MARQ10MARQ10Touch
MARQ11MARQ11Touch
Watch Face Data Customization Options
Depending on the watch face you have selected, the data options may look slightly different compared to the examples below. Some watch faces may also include larger graphical data fields for things like VO2 max or Training Status.
Data Field UTC
Universal Time Coordinated
Displays Universal Time Coordinated (UTC).
UTC is the successor to Greenwich Mean Time (GMT).
Data Field Respiration Rate
Respiration Rate
Describes how often you inhale and exhale in a minute.
Data Field Pulse Ox
Pulse Ox
Display your most recent Pulse Ox reading.
Data Field Sunset Sunrise
Sunset/Sunrise
Displays Sunset/Sunrise time.
An arrow will point down for sunset and up for sunrise.
Data Field Steps
Steps
Displays daily step count.
Data Field Floors Climbed
Floors Climbed
Displays floors climbed for that day.
Data Field Recovery Time
Recovery Time
Displays the number of hours left on recovery time.
Data Field Status Icons
Status Icons
Displays icons when alarms, Do Not Disturb mode, phone connection, or headphone connection are active.
Data Field Notifications
Notifications
Displays the number of notifications.
Notifications number will not be cleared until they are cleared from the phone.
Data Field Intensity Minutes
Intensity Minutes
Displays the number of intensity minutes generated for the week.
Data Field Running Total
Weekly Running Total
Displays distance of all running activities for the week, except Trail Run.
Data Field Cycling Total
Weekly Cycling Total
Displays distance of all cycling activities for the week.
Data Field Heart
Heart Rate
Displays the reading taken from the optical heart rate sensor (OHR).
The OHR sensor must be on to get a reading.
Data Field Day and Month
Day and Month
Displays the current calendar date and month.
Data Field Weekday and Day
Weekday and Day
Displays the current calendar date and day of the week.
Data Field Calories Burned
Calories Burned
Displays total calories burned for the day.
Data Field Calendar
Calendar Notifications
Displays the time of the next calendar notification.
Data Field Battery
Battery Life
Displays the remaining battery life.
Can display days remaining or percentage.
Data Field Barometer
Barometer trending line and the barometer reading
Will display the current barometer pressure in millibars.
The barometer trend line considers the last 6 hours, broken into two 3 hour segments. If there is a 2.3 millibar change over the 3-hour segment, the line will curve up or down depending on the direction of change.
Data Field Altimeter
Altimeter Reading
Displays the current altimeter reading.
Data Field Weather High Low
Weather High and Low Temperatures
Displays the high and low temperatures for the current day's forecast.
Data Field Current Weather
Weather
Displays the current weather.
NOTE: If you delete one of the pre-loaded watch faces, the watch will have to be reset back to default settings to recover the watch face. See your owner's manualfor information about how to reset your watch to default settings.
