How to Install, Remove or Replace an Automotive Adhesive Magnetic Mount
Install:
Your Garmin Dash Cam mount came assembled with an adhesive magnetic disc inserted in the mount.  After installing the mount, the adhesive and metal disc will stick to the windshield as you pull the mount away.
Watching the video below is a great way to see how to install the magnetic mount for your dash cam.
Remove:
If you intend to remove an adhesive magnetic disc, you may use adhesive removal products sold in most hardware stores to remove the adhesive from your vehicle's windshield or dashboard.  If additional leverage is needed, dental floss can be used in a side-to-side motion between the magnetic disc and windshield surfaces.
These products are intended to help remove the adhesive magnetic disc without damaging any surfaces. It is recommended to first apply the adhesive remover in a less visible area to test for color damage. Once removed, the adhesive itself will not be reusable.
Replace:
Included in your original dash cam box is an extra adhesive magnetic disc in a poly bag to use if needed.  Additional compatible mounts and accessories can be found for your dash cam on the product page on www.garmin.com.
