Turning Smart Notifications off or on With vivosmart
The Smart Notifications feature on a vivosmart can be turned off or on as needed. This feature is only available when paired with a compatible smartphone.
To turn this feature off or on, follow the steps below:
  1. Open the Garmin Connect app.
  2. Access the menu by selecting More (bottom right).
  3. Select Garmin Devices.
  4. Select the vivosmart
  5. Select Device Settings.
  6. Select Display.
  7. Select Visible Screens.
  8. Locate Notifications.
    • To Enable this feature, slide the switch to the right.
    • To Disable this feature, slide the switch to the left.
The Smart Notifications should now be Enabled or Disabled as needed.
