Navionics Boating: Community Edits - How to Add and Edit
To Add an Item to Share with the Navionics® Community
  1. Select a spot on the map to add the item using the crosshairs.
  2. Tap the question mark (?) on the right side.
  3. In the Quick Info screen, tap the Add button.
  4. Choose a Category.
  5. Pick the specific item you want to add.
  6. Add further details about your item.
  7. Tap the Add button to save.
Items added to the map will be marked with a small green circle with a (+) symbol.
To Edit or Delete an Item that Already Exists on the Mapping
  1. Select an object on the map using the cross hairs.
  3. In the Quick Info screen, choose the item to edit.
  4. Tap Edit in the upper right.
  5. From the options, select Edit, Move, or Delete
NOTE: Items that are part of the physical Navionics chart data, like a buoy, cannot be physically deleted from the map. These items will still remain on the map, but be denoted with a small red X marking it as an item a user reports as no longer existing. Any errors you may find in the charting can be reported through our online form at https://supportforms.garmin.com/form/navionics-cartography-error-report/.
Related
