Understanding The Wi-Fi Limitations of The GDL 59
The GDL® 59 datalink has some very specific Wi-Fi limitations and it is recommended that they are followed so that there are no connectivity issues.
  • B/G or G mode.
  • Fully IEEE 802.11g compatible.
  • All access points must be coupled to a DHCP server.
  • The network shall support data transfer via HTTP and HTTPS and allow outgoing connections to the internet on port 80 and port 443.
  • Networks that include web proxies, captive portal, or other elements that require user credentials, including a username and password or a redemption or access code; or require action such as accepting a user agreement, are not supported for data transfer from the GDL 59.
  • The access point must be capable of receiving at a rate of 18 Mbps.
  • The Wi-Fi network shall be compatible with WEP64, WEP128, WPA-PSK, or WPA2-PSK encryption formats, and with all of those formats associated encryption combinations and options; or compatible to be used with no encryption.  WPA-Enterprise and WPA2-Emterprise are not supported.
  • If WPA-PSK or WPA2-PSK are used, the access point must not be set to auto-select between them.
Related
