Edge 1050 Battery Life Expectations
The battery life of your Edge® 1050 cycling computer may be impacted by the usage of features within the product or the way it is used. The information in the table below is presented to help outline the conditions used to determine the estimated battery life specification. The additional usage of these features or other features not included below may result in reduced battery life. The information presented below is presented as a general guide for reference only on the Edge 1050 model.
Select a use case scenario below for information on expected battery life:
Edge 1050 - Low Use
GPS SettingGPS
Number of Paired ANT Sensors 30
ANT Sensor TypeN/A
Phone Paired & ConnectedNo
LiveTrack EnabledNo
Backlight Brightness 1Auto
Backlight TimeoutStays On
Notifications Received per Hour0
User Interface Interactions per Hour5
User Interface ConfigurationsActivity Timer Page
Following a Course 2No
Operating Temperature Range10C - 40C
Estimated Battery LifeUp to 24 hours
Back to Top
Edge 1050 - Battery Saver
GPS SettingGPS
Number of Paired ANT Sensors 32
ANT Sensor TypeSpeed, Cadence
Phone Paired & ConnectedYes
LiveTrack EnabledYes
Backlight BrightnessAuto
Backlight Timeout15 Second
Notifications Received per Hour4
User Interface Interactions per Hour10
Following a Course 2Yes
Estimated Battery LifeUp to 60 hours
Back to Top
Edge 1050 - Demanding Use
GPS SettingMulti-GNSS Multi-Band
Number of Paired ANT Sensors 34
ANT Sensor TypeSpeed, Cadence, Heart, Power
Notifications Received per Hour8
User Interface Interactions per Hour15
User Interface ConfigurationsMap Page
Estimated Battery LifeUp to 20 hours
Back to Top
1 In Auto Brightness mode, the Edge 1050 display backlight will automatically adjust its brightness based on ambient light conditions, and battery life is impacted accordingly. The battery life estimates are based on average riding conditions. Note that in Manual Brightness mode, higher backlight brightness settings will decrease battery life.
2 Each course is unique regarding the number and type of alerts generated. The number of alerts generated by the course will impact battery life. Courses that generate a large number or frequent alerts will consume more battery life than courses with fewer turns or alerts.
3 The usage of a Garmin Varia Rearview Radar with your Edge device may result in an additional reduction in battery life. This potential, additional reduction in battery life will vary depending upon traffic conditions and the number of vehicles in the vicinity of the radar device during operation.
