Managing Saved Locations on Chrysler Uconnect CTP Devices
Choose a topic below for saving a current location, a recently found location, or a search result.
To save a current location
  1. Touch View Map
  2. Touch the vehicle icon on the map
  3. Touch Save or Save Location
  4. Type the name you would like to assign to the location
  5. Touch Done
  6. Touch OK
The location may now be accessed in the Favorites list.
To save a recently found location
  1. Touch Where to?
  2. Touch Recently Found
  3. Touch the desired location
  4. Touch Save
  5. Type the name you would like to assign to the location
  6. Touch Done
  7. Touch OK
The Recently Found location has now been saved as a favorite
To save a search result
  1. Search for an address, POI, etc, using the options available in the Where to? menu
  2. When the location is found, select it from the search results
  3. Touch Save
  5. Touch Done
  6. Touch OK
The Search result has now been saved as a favorite
To edit a saved location
  1. Touch Where to?
  2. Touch Saved or Favorites
  4. Touch Press for More
    • Some devices skip this step
  5. Touch Edit
  6. Touch the information you would like to change
    • You may change the name, map symbol, phone number, and category
