Using the Find My Phone Feature on a Garmin Watch
Find My Phone allows you to locate your phone when it is paired and within Bluetooth® range of your Garmin® watch. For details about Bluetooth range, see What Is the Maximum Bluetooth Range of My Garmin Watch or Edge Device?
When the feature is activated, your phone will emit an audible alert and vibrate. Android users can also flash their camera light if camera permissions are enabled for the Garmin Connect™ app. Some Garmin watches will also display the Bluetooth signal strength which will increase as you move closer to your smartphone.
For specific instructions on using this feature, search "Find My Phone" in your owner's manual
Find My Phone Icon
Orange Phone Icon with Question Mark
Android Users
The last used audio channel on your phone may control how the alert is heard. For example, if your phone's last used audio channel was Bluetooth, the Find My Phone audio alert will likely sound through your Bluetooth headphones instead of the phone’s speaker. If the feature is not working for you, check this setting:
IMPORTANT: The steps below should work for the majority of Android models. If you cannot find the settings using the steps below please contact your phone's manufacturer.
Most Android Phones:
  1. Open the Settings app of your phone.
  2. Select Apps or Apps & Notifications.
  3. Select Connect.
  4. Select or look under Advanced.
  5. Select Display over other apps.
  6. Enable Allow display over other apps.
Most Samsung Phones:
  3. Select Connect.
  4. Select Appear on Top.
  5. Toggle Allow Permissions to turn on or off.
iPhone Users
If the Garmin Connect app is swiped closed, the Find My Phone feature will not work, as it requires that the Garmin Connect app be open or running in the background. For details, see Some Garmin Connect App Features Are Not Working On My iOS Device.
Related
