Editing Bullet Properties on a Foretrex 901 Ballistic Edition
To edit the bullet properties on a Foretrex® 901 Ballistic Edition wrist-mounted navigator follow the steps below. You can also edit bullet properties through the Applied Ballistic Quantum™ app with your compatible smartphone or tablet. (See the related content below if needed to create a profile)
  1. From the Applied Ballistics page, press ENTER.
  2. Select PROFILE > BULLET PROPERTIES.
  3. Select an option:
    • To automatically enter bullet properties from the Applied Ballistics bullet database, select BULLET DATABASE, select your ballistic solver, and select the bullet caliber, manufacturer, bullet, and drag curve.
      NOTE: You can select the caliber of your bullet by searching a list of bullets within that caliber. Not all bullet names match the actual bullet caliber, for example a 300 Win Mag is a .308 caliber bullet.
    • To manually enter bullet properties if your bullet is not in the bullet database, using the up and down buttons scroll through each field and select ENTER to edit the values.
      NOTE: You can find this information on your bullet manufacturer's website.
Helpful Links
Related
