Why Am I Seeing "Wake up Approach R10?" in the Garmin Golf App?
If you forget to power off the Approach® R10 launch monitor when you are done using it, you may receive the following prompt in the Garmin Golf™ app:
"Wake up Approach R10? Your Approach R10 device has gone into sleep mode. Would you like to wake it up?"
This is because the Approach R10 monitor automatically disables radar and goes into sleep mode to conserve power when movement is not detected. If you are finished using the Approach R10 monitor, you can select Ignore in the app and power off the Approach R10 monitor by holding the button for one second.
NOTE: If the Approach R10 monitor is not level or is on a tilt, it can also cause it to go to sleep and the message will appear. Ensure the tripod is placed on a level surface to prevent device from being on a tilt.
