Can I Disable Phone Call Notifications on the Venu Series Watch?
As long as your voice call compatible watch is in range or connected to your phone when a call comes in, the watch will act as a Bluetooth® accessory allowing you to make and receive calls directly from the watch. The only way to turn off phone call notifications on the Venu® 2 Plus smartwatch is to disable Bluetooth on your phone or the watch. You can disable or edit phone call notifications on the other compatible watches by following the steps below:
  1. Access the menu of your watch.
  2. Select Settings > Notifications & Alerts > Smart Notifications.
  3. Choose either General Use or During Activity.
  4. Select Calls.
  5. Tap any of the options you would like to change.
Related
