Pairing a zumo 390 with a Bluetooth phone or headset
You can use your zumo 390 with your cell phone, headset, and/or helmet by pairing them. Before you begin, set your Bluetooth phone or headset to Find Me/Discoverable mode. If you are not sure how to do this, refer to the owner's manual or documentation that came with the device.
In order to connect to the zumo, the cell phone must be running either Android 2.1 and newer or an iPhone 4S and newer running iOS 6.0 and newer. If connecting a headset, it must support the hands-free profile and use Bluetooth version 1.1 or higher. Note: These are general guidelines, and do not guarantee compatibility.
Your zumo requires that you have a headset or helmet paired along with your mobile phone to the device in order for the Bluetooth feature to work.
To enable Bluetooth on your zumo:
- Touch Settings
- Touch Bluetooth
- If no check mark is present, touch the box next to Bluetooth
Bluetooth will now be enabled on your device.
To pair and connect your phone with your device:
- Touch Settings
- Touch Bluetooth
- Touch Scan for Devices
- Touch OK on the message that prompts you to set your headset/helmet to Find Me or Discoverable mode
- Touch Pair on the phone
- You will receive the following message on the zumo, "No headset connection found. Phone call service is not available. Please connect a headset."
- Touch OK
Your zumo and phone should now be paired.
To pair and connect your headset or helmet with your device:
- Touch Settings
- Touch Bluetooth
- Verify that the headset or helmet is in Discoverable mode
- Touch the name of the desired headset or helmet from the list
- Touch OK
The zumo should now be paired with both the phone and headset or helmet.
A detailed video tutorial for pairing with a headset is available below.
Support: Pairing a Headset to a zumo |
