Verifying Maps Installed on an Automotive Device
NOTES:
To Check the Map Version Loaded On Your device:
1. Touch Settings or the Wrench icon
2. Touch Map
3. Touch Map Info
4. Within this section, you will see all of the mapping loaded onto the device.
If there is no checkmark next to the map(s) listed, touch the box to add a check. This will enable the mapping on the device.
If the Map Info screen is inaccessible or blank, see Restoring Maps Missing or Deleted Off an Automotive Device.
