Garmin Jr. App Bluetooth Troubleshooting
Most Bluetooth connection issues can be solved by restarting your phone or by resetting the vivofit jr. device:
NOTE: Resetting the device resets the move bar but does not erase any of your data.
  1. Hold the device key for 10 to 15 seconds until the screen turns off.
  2. Release the device key.
  3. The device resets, and the screen turns on.
If you continue to have an issue, the following topics cover Bluetooth connection issues with the Garmin Jr. app.
Select a Topic Below That Best Describes Your Issue:
My vivofit Jr. Device Not Found During Pairing Process
NOTE: It is important to pair the vivofit jr. device directly through the Garmin Jr. app and not through the phone or tablet's Bluetooth settings. If the vivofit. jr device is paired in the phone or tablet's Bluetooth settings before adding it in the Garmin Jr. app, it may not be found by the app.
vivofit jr. Device is Listed in the Bluetooth Settings
If it is, go to your mobile device's Bluetooth settings, find the device you're trying to pair, and choose "Forget" before attempting to pair it in the Garmin Jr. app again. If it still won't pair, restart your mobile device.
Does the Battery Need to Be Replaced?
A vivofit jr. device that is unresponsive to a button push and displays either a triangle on the screen or a blank screen with a red bar is likely experiencing a low battery condition. Changing the battery should restore functionality. To replace the battery, refer to your owner's manual.
Is the vivofit jr. Device in Pairing Mode?
This will be indicated by seeing signal bars on the display of the vivofit jr. device. If this is not displayed, press and hold the button until signal bars is displayed on the screen then release the button.
Has the vivofit jr. Device Been Paired With Any Other Tablets or Smartphones?
A vivofit jr. device can be paired with a total of 3 mobile devices. If the vivofit jr. device has already been paired with other mobile devices this may interfere with pairing to a new smartphone or tablet (particularly if those mobile devices are powered on and within range). If this is the case, it may be necessary to turn off Bluetooth on previously paired mobile devices or remove the vivofit jr. device from the mobile device it was previously paired with before pairing it to a new smartphone or tablet. For more information, see Removing and Adding a Watch from the Garmin Jr. App
"Unable to Pair" or "Kid's Band Disconnected" Error Message
NOTE: It is important to pair the vivofit jr. device directly through the Garmin Jr. app and not through the phone or tablet's Bluetooth settings. If the vivofit. jr device is paired in the phone or tablet's Bluetooth settings before adding it in the Garmin Jr. app, it may produce an error when pairing in the app.
Is the vivofit jr. Device Listed as a Paired Device in Your Smartphone or Tablet's Bluetooth Settings?
If it is, go to your mobile device's Bluetooth settings, find the device you're trying to pair, and choose "Forget" before attempting to pair it in the Garmin Jr. app again. If it still will not pair, restart your mobile device.
Is the vivofit jr. device in pairing mode?
A vivofit jr. device can be paired with a total of 3 mobile devices. If the vivofit jr. device has already been paired with other mobile devices this may interfere with pairing to a new smartphone or tablet (particularly if those mobile devices are powered on and within range). If this is the case, it may be necessary to turn off Bluetooth on previously paired mobile devices or remove the vivofit jr. device from the mobile device it was previously paired with before pairing it to a new smartphone or tablet. For more information, 7see Removing and Adding a Watch from the Garmin Jr. App.
vivofit Jr. Device is Paired to the Garmin Jr. App but Not Syncing
Try Manually Syncing
A vivofit jr. device will periodically send data automatically to the nearest paired mobile device, but you can also manually send data at any time by following these steps:
  1. Bring the device near your smartphone or tablet
  2. Open the Garmin Jr. app
  3. On the vivofit jr. device, hold the key until you see the signal bars icon
  4. Wait a few seconds until the red move bar icon begins to slide back and forth
    • Once connected, two rotating arrows will appear on the device indicating that data is being uploaded
  5. From the app, swipe down to refresh data
Is the Software on the vivofit jr. Device up to Date?
A vivofit jr. device must be kept near the paired smartphone during the transfer of a software update which can take up to 10 minutes. Failure to do so may result in it being unable to finish syncing.
  1. Press and hold the button until signal bars is displayed on the screen then release the button
  2. Press the button 4 times, you should see the lowercase i icon
  3. Press and hold the button until the device information page is displayed.
To Update the Software:
  1. Bring the device near the smartphone
  3. On the vivofit jr. device, press and hold the button until signal bars is displayed on the screen then release the button
  4. two rotating arrowswill appear while the sync is in progress
  5. cloud icon with a down arrow will appear while the software update is transferred. Keep the vivofit jr. device near the paired smartphone during the transfer of the software update which can take up to 10 minutes.
Try Removing the vivofit jr. Device and Reconnecting It
None of the Above Topics Cover My Issue
Confirm that you are running the latest version of the Garmin Jr. app.
  • Choose your app store below to check for and install any available updates:
Apple App Store logoGoogle Play Icon
Check for and install any available updates for your phone.
  • Consult your phone manufacturer for assistance if needed.
Review the following to confirm your phone meets our minimum system requirements: Garmin Jr. Mobile App Bluetooth Minimum Device Requirements
