Transferring User Data from the Navionics Application to ActiveCaptain
To transfer user data, like tracks, routes, and markers, from the Navionics application to ActiveCaptain, use the following steps:
NOTE: Navionics+ subscription is required.
  1. In the Navionics application, select Menu
  2. Select items located in Tracks, Routes, or Markers
  3. For each option, choose Select (iOS) or the 3 dots icon (Android)
  4. Tap Select All or check each piece of data individually
  5. Tap the Share icon; Navionics iOS Share Icon Example for iOS or Navionics Android Share Icon Example for Android
  6. Choose Export GPX File
  7. Select ActiveCaptain to export directly to the ActiveCaptain application
  8. ActiveCaptain will open and ask "Import user data?"
  9. Select Import
  10. ActiveCaptain will then confirm the data has been imported
