Delete Call History on an Automotive Device
There is no way to remove the call history on your Bluetooth-enabled automotive device while paired to a mobile phone. In order to remove calls from the call history, the connection must be dropped and the entries must be manually deleted from the phone. To drop the phone, the Bluetooth can be disabled on the Garmin device.
To Disable Bluetooth on Most Devices:
  1. Touch Tools
  2. Touch Settings
  3. Touch Bluetooth (may need to touch the down arrow)
  4. Touch the Enabled box below Bluetooth
  5. Touch Disabled
  6. Touch Save
The two devices will now be disconnected, then remove the desired entries from the mobile phone's call log. If you are unsure on how to do this, refer to the phone's owner's manual or contact the phone's manufacturer. Once the devices are paired again, the deleted entries will no longer show on the Garmin device.
