List or Map View of Saved or Recent Locations
When searching for locations, the device allows you to view the results in a list or on a map. You will see these options on many lists of results on your device, including in your Saved and Recent menus. The tabs on the right side of the screen toggle between the two options.
The top tab on the right shows the results in a list:
This is the default setting. You can choose where you want to go from the list by touching the desired destination.
The bottom tab on the right shows a selected result on a map:
You can drag the map to view additional search results. Touch an icon to see information or to begin navigation.
